OK here is the deal, I reformated my hard drive, got rid of everything, and decided to start from scratch. I have asf files on cd that I tried to play that would have static sounds when playing, but when I minimized it the sound would be perfect. So I concluded it is not a file problem. When I reformated I downloaded the new windows media player. The asf file played perfectly. Then I downloaded the nimo divx bundle, and of course the static problems came back. So I uninstalled it, then I downloaded the divx 5.01 bundle and the static problems occured. What suggestions do you all have? Thanks
Results 1 to 1 of 1
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 20:21 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
