Can someone please outline the procdure and give me guidelines and the the equipment need on how to convert video cassettes and audio cassettes to cds.
If you can let me know in the following manner:
1)Equipment needed.Type.(video card, cables etc..)
2) Software needed.(preferably free..pls)
3) Procedure for conversion for both audio and video.
Thanks a lot. Will really appreciate it.
Regards,
Divi
You'll want to read the "HOW TO" guides at the left - first Newbie, next capture, then author, then burn.
Most of the software if not all will be free. To capture video you will need a hardware card. The capture card list is offline until next month - go to your local store & browse.
What type of discs are you looking to make exactly?Panasonic DMR-ES45VS, keep those discs a burnin' -
Can someone please give me clearer details...after reading those i am confused.....can anyone just tell me the things in a simple manner...without irrelevant info to be read.
thanks a lot -
If you want to rip your audio cds' download CDex:
http://www.cdex.n3.net
As for video do as Kitty says and read the "How to Newbie" section,
there are so many options you will have to do some searching to find
what is best for you. -
I found that my HiFi VCR outputs gorgeous stereo sound with very little hiss.
Assuming that you don't have a Dobly NR tape deck, recording onto a HiFi VCR may help you reduce tape hiss. Then you can output the VCR audio to computer giving you great audio without having to mess with audio filters on the computer which I've had very little success.
I will soon test if my VCR does real time HiFi audio filtering via audio inputs (thereby negating the need to record with the VCR) or if I need to record to the VCR to get good signal to noise ratio.
Audio Cassette Conversion
By wyclef in forum AudioReplies: 20Last Post: 18th Feb 2011, 11:04 -
Best way to extract audio from old Cassette tape?
By Han Solo1 in forum AudioReplies: 5Last Post: 28th Sep 2010, 21:45 -
Capturing cassette audio - convert to wavs - will this work?
By Theresa in forum AudioReplies: 12Last Post: 16th Aug 2009, 04:33 -
cassette audio tape
By zoobie in forum AudioReplies: 7Last Post: 4th Jul 2008, 00:06 -
Best program to convert Audio Cassette Tape to WAV
By jimcornetet in forum AudioReplies: 8Last Post: 14th May 2007, 16:48
