  1. sorry for the dumb question. but i read the guide on "how to fit a dvd rip to one disk" using cladxp etc. but the problem is i need to fit a dat file onto one disk is there a guide on howto do this. i tried to modify the last guide but still no luck.
    please help...........many thanx from a complete newbie.
    help should be free and plentiful..........enjoy
  2. How big is the file?
    Panasonic DMR-ES45VS, keep those discs a burnin'
  3. 1.2 gig, but i cant see why a dvd rip can be put on one disk and a dat or converted mpeg cant. maybe i am wrong.......thanx for the reply mate
  4. You have limited choices:
    First you'll want to convert the DAT back to MPG (see convert section)
    Then you can
    1) Split the MPG & burn 2 discs or
    2) Resample using a MPEG encoder like TMPGenc. You will loose quality but it will beon one disc.
