I have the latest QT pro and I can not open 3 mov files I downloaded last night.
Usually if there is a problem QuickTime will connect and download the component needed - but thats not happening. I even run QuickTime update and it says everything I have is current.
The error message says "You may esperince problems plaing a track in "Test.mov" becaue the required compressor could not be found. Would you like to close the move or contine?"
Shouldn't the latest Quicktime have the latest updates? I'm at a loss with this one - any hints greatly apreciated!
your pal,
Stinky -
Will they open in TMPGenc with the plugin?
Panasonic DMR-ES45VS, keep those discs a burnin' -
It opens in TMPGEnc, Bink and Smacker and Quicktime - but it only shows white for the video because the "correct" decompressor can't be found???
your pal,
Stinky -
Sounds like those "protected" MOVs the studios use
I would agree but why wouldn't a legit version of QT Pro be able to play it
and I doubt it's protectedit's ummm.... adult material
your pal,
Stinky -
I got it figured out - and it was something I was unfamilier with
I had to get a new codec for Quicktime called 3vix
http://www.3ivx.com/download.html
I've never had to add a codec to Quicktime - you just download it and put the .qtx file in %WinDir%\system32\QuickTimeyour pal,
Stinky
Can QuickTime Pro Convert XDCAM MP4 to .mov?
By boriega in forum Video ConversionReplies: 2Last Post: 15th Sep 2010, 15:17 -
.mov to .flv converter (upgrade to quicktime pro the answer)?
By claydoctor in forum MacReplies: 1Last Post: 29th May 2009, 06:24 -
No sound in MOV och MP4 when I use quicktime pro
By Cazz in forum Video ConversionReplies: 2Last Post: 3rd Sep 2008, 15:02 -
Problem converting quicktime .mov files to mpeg-1
By jtk in forum ffmpegX general discussionReplies: 8Last Post: 2nd Sep 2008, 18:42 -
.mov wont open in quicktime
By lonewolfsas2k4 in forum Newbie / General discussionsReplies: 1Last Post: 4th Nov 2007, 11:25
