Hi, I I know that there is a function which allow to crop the video in VirtualDub (cut the edges and this also cause video to get resized).
But I wonder if there is an option only to clip the edges (hide some parts).
I want to create an SVCD disk (watch it on tv set) - and tv signal which I've recorded previously to .AVI has a noises at the edges of the screen. I want to hide them (but not resize the video), because this parts of video will never be seen on TV set, and I think that such noises use to much of MPEG2 bitrate which can be better used on the other parts of screen.
Thank you for any help.
Best regards.
Patryk.
I don't know if you can mask in VirtualDub, but you certainly can in TMPGEnc (if that is your choice for encoding).
BeTa
Trying to encode a clip to XviD to join another using VirtualDub ...
By Phat J in forum EditingReplies: 21Last Post: 5th Jun 2012, 02:08 -
Sync/align one short clip into one big clip
By diamondback in forum AudioReplies: 1Last Post: 2nd Nov 2011, 09:31 -
Do I need to stop clip analysis in order to export clip for dvd
By maevek1 in forum MacReplies: 0Last Post: 9th Apr 2008, 08:26 -
How Do I Put A Custom, Created Slow Motion Clip Back In? (Virtualdub)
By WishMaker in forum EditingReplies: 8Last Post: 24th Oct 2007, 11:14 -
d/l trailer (video clip) but no video just audio
By leinan in forum Newbie / General discussionsReplies: 0Last Post: 25th Jun 2007, 00:33
