Hello!
I have a couple of SVCD images, but unfortunately my DVD player (Toshiba SD-1750) does not recognize the SVCD format (gives a "Disc Error" message).
I attempted to "fool" it by ripping the MPEG2 stream from the SVCD image, which worked fine, and then using vcdimager to burn the image in VCD format (which my DVD player *does* recognize). Unfortunately, when I popped the CD into the DVD player, id did indicate that it was playing, but I was getting nothing but black screen. <shrug> So much for that idea.
I know it' spossible to convert an MPEG2 stream to MPEG1 (using DVD2AVI, I think??), but I was wondering if such a tool exists for Linux? It doesn't matter if it's GUI or commandline-based (actually, commandline based would be preferable).
Thanx, in advance, for your help.
Alan
transcode (see other posts for links). It is command-line and you can do something like this:
transcode -V -y mpeg -F v,4 -E 44100 -b 224 -o test -i mymovie.mpg
tcmplex -o test.mpg -i test.m1v -p test.mpa -m vDave.
Best tool for HD conversion
By carlmart in forum Video ConversionReplies: 27Last Post: 6th Feb 2011, 11:28 -
Best Conversion Tool?
By cdaz in forum Video ConversionReplies: 1Last Post: 3rd Feb 2008, 19:06 -
restartable conversion tool
By djelimon in forum Video ConversionReplies: 5Last Post: 30th Dec 2007, 10:44 -
Looking For A Cropping/Splitting/Converting Tool that supports MPEG2
By LordOfTheStrings in forum EditingReplies: 21Last Post: 12th Nov 2007, 12:09 -
Best DV to DVD conversion tool
By whenloverageswild in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 24Last Post: 2nd Nov 2007, 00:50
