Hi,
I have a 2 CD Divx of excellent quality
and the objective is to create vcd for playing on standalone
DVD player which plays VCD.
CD1 = Filename.avi 733,296,646 - 1:31:57 Runtime
VDub nfo = Frame size - 640,272 -23,976 fps
Decompressor - DIVX 5.0.2 codec
Cd2 = Filename.avi 731,994,112 - 1:25:22 Runtime
Followed the excellent tutorial at
http://www.vcdhelp.com/divxtovcd.htm
for CD1 and mpg file produced = 961,778,104 = too large for 74 min cd
Can anyone point me to tutorial for this example as I
guess somehow part of cd1 = vcd 1, remainder cd1+partcd2= vcd2, remainder cd2 = vcd3
Or am I on the wrong track.
Does your burner support 99min. cd-r's?If not read:
http://forum.vcdhelp.com/viewtopic.php?t=84759 -
You are on the wrong track, but all the info you need is on this site. First, join both avis using virtualdub. Extract the audio as an uncompressed wav using Virtualdub. It will be be big (~2GB!) Then, having chosen a template to correspond to the framerate, NTSC(film) in this case, use TMPGenc's batch list facility to create 3 VCD mpgs. Then burn to VCD with Nero or VCDEasy. Your movie is nearly 3 hours, so you cannot fit on less than 3 x 74 min CDs.
You could use what you already have, and produce a second mpg, join these and split into 3 using TMPGenc. However, if you haven't used NTSC(film) template, I'd start again. 8) -
Start again sounds good, so I'm off to try and join the 2 files
as step 1.
Speed of help is great, thanks a lot. -
Using VirtualDub to join the 2 avi's results in error when selecting
2nd avi : audio streams at different bitrates
Any suggestions to overcome this problem? -
In which case you will have to deal with each DivX in turn. Convert to mpg, and join mpgs (with TMPGenc), then split into 3. It's a little more complicated than splitting avis with Virtualdub, but not much. 8) You'll find guides to this also on the site.
Success,
As you said, created the 2nd mpeg via vdub
Joined the 2 mpegs with TMPenc
Split to 3 in TMPenc (after I figured it out)
Burned and test played on DVD standalone
Many thanks for the help
PAL or NTSC camera : does it matter ?
By kirby7777 in forum Authoring (Blu-ray)Replies: 9Last Post: 14th Aug 2011, 14:51 -
Does size really matter?
By ingeborgdot in forum ComputerReplies: 21Last Post: 25th Jun 2011, 10:11 -
So is any DV codec better than MainConcept at decoding? Does it matter?
By Asterra in forum Video ConversionReplies: 11Last Post: 20th May 2011, 22:59 -
Why does the disc speed matter with the burning?
By coody in forum DVD RippingReplies: 20Last Post: 31st Jan 2008, 18:39 -
Does it matter what you use to capture DV tapes to computer?
By deacea in forum Capturing and VCRReplies: 2Last Post: 18th Nov 2007, 23:20
