  1. Guest
    When I capture in 25 fps, the avreage rate is about 25.0448 fps, and this leads to dropped frames. Do anyone know how to fix this problem. The audio and vido do not match when I´m capturing.
  2. Are you using VirtualDub to capture?
    I found the same problem and switched capture apps to AVI-IO. Far less frame drops. ( I've probably put this in half a dozen replies today. It's gonna start looking like a vendetta of some sort against VirtualDub. It's not. I love it. Just not for capturing. )
    Good Luck,
    Ian
