I recently tried DVD2SVCD and found the quality to be very good, however the process is just click and go and I would like more control over the end result i.e where the movie is split and the option to only encode 1 cd at a time rather than 50 hours to do all 3 cd`s at once!
I am familier with the settings in TMPGEnc but I cannot get the same quality from it that I get using TMPGenc through DVD2SVCD.
I have inputed the setting from the automaticaly generated file from DVD2SVCD (svcdinfo.txt) but still not the same quality. Does anyone know exactly what settings I should be using or how I can find Out.
I have searched the forums but cant find anything relating to this topic, I have also tried the DVD2SVCD forum but found them to be very unfriendly!!
I also emailed Sefy levy who suggested this forum to me
I guess what I am asking for is the DVD2SVCD Template for TMPGEnc.
Thanx in advance for ANY help whatsoever![]()
JaYbEe
Thanx, I didnt know the settings were in there, I looked and that explains some things but, Im still lost on a few others like for instance on DVD2SVCD under the `Conversion` tab You can set the Deinterlace setting to Telecide (PAL) but in TMPGEnc I cant find that setting. I know its probably under sometihng more technical than that but I just cant find It........I guess I should be on the newbie forum.Thanx for the reply anyway.
JaYbEe -
The settings used is a mixture of tmpgenc settings and AVISynth settings. To get the full view of what is being done open the AVS file in notepad.
TMPGEnc Settings?
By chronic777 in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 09:14 -
Help with TMPGEnc 4.0 XPress Settings
By mister_to_you in forum Video ConversionReplies: 0Last Post: 20th Jun 2008, 09:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
TMPGEnc DVD settings
By Bully9 in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 08:22 -
Doubt about TMPGEnc Plus' settings
By alvabass in forum Video ConversionReplies: 1Last Post: 13th Jun 2007, 11:52
