hello, I'am trying to add subtitles to an mpg file and then encode it to a VCD but there is a problem. First of all I've read all the guides here. I'm loading the mpg file from Virtual Dub and then the textsub filter. Then I'm starting the frameserv saving a vdr or vdr.avi file. I'm opening Tmpg encoder and when I'm trying to load the .vdr or vdr.avi file it tells me that this file type is not supported. I've disabled the Direct show multimedia file reader but still the same problem.Can someone help me please? Sorry for my bad english.
Before starting frame server you have to install handler. see this guide: http://www.vcdhelp.com/srtsubsvirtual.htm
I have no problem frameserving from VD 1.4.10 to TMPGEnc 2.54
I had problems sometime back and found a fix on the net: under the TMPG folder, delete the settings files, they are called CurrentCfg.tpr and TMPGEnc.ini (don t worry, they will be regenerated next time TMPGEnc starts). Install the Virtual Dub handler again, restart TMPGEnc.
In TMPGEnc, there is no need to disable anything. For me, I actually promoted the DirectShow filters and make sure to call the handler file filename.avi and not filename.vdr. Works like an absolute charm. -
ok I think it works, I'll test it soon beacause I've no time now. Thanks alot!!
Adding subtitles to VOB file
By Booooom in forum SubtitleReplies: 19Last Post: 24th Dec 2020, 19:12 -
adding subtitles to avi file
By dragonhead08 in forum ffmpegX general discussionReplies: 1Last Post: 2nd Jan 2009, 09:18 -
Adding Subtitles to divx w/ a .sub file
By sean2a in forum SubtitleReplies: 5Last Post: 28th Sep 2008, 17:23 -
Adding Subtitles To An .AVI File
By thesal523 in forum SubtitleReplies: 2Last Post: 10th Aug 2007, 13:16 -
a problem with adding subtitles to avi file by autoGN
By 3l8x in forum Newbie / General discussionsReplies: 2Last Post: 16th Jun 2007, 02:28
