  1. I have amovie on SVCD but the audio is out of sync,VCD play ok on my standalone DVD player ,can I convert it back to just VCD so how I can fix the audio problem.I dont have the files on my pc ,the movie is on 4 discs how can I do it.Thanks I appreciate any help.
  2. Hello .
    only flask 0594 can make SVCD ok !
    take it , make sure to use BBMPEG and in the EXPORT TAB click to set encoding to the SECOND <if movie 1 monute it is 60 second etc...>
    locate at
    FLASK MPEG OPTIONS
    GENERAL
    COMPILING TIME
    AND CLICK on second !
    take the flask from
    http://www.geocities.com/installflaskmpeg0594
    it also have a setup options !
