ok, I downloaded Bumfights Cause for Concern Vol.1 (SVCD). I extracted the .mpg from the bin/cue with CDMage, now with the problem, I have PowerDVD and WinDVD 4 and they both load the file, blank screen no audio and the navigational slider is moving fast as if the movie were in super fast forward, but its not. powerdvd gives me an error code "80070026 reached the end of the file". hope u can help me. thanx
try extracting the mpg with VCDGear instead or mounting the cue/bin in Deamontools and playing it as a regular CD.
Well, I am the slime from your video.
Oozin' along on your livin'room floor. -
ok problem is fixed, I did the first thing you said with vcdgears, I took the cue/bin -> mpeg fix errors and now its perfectly fine. by the way if ur into insane stuff, bumfights is at the top. thanx for your help
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
svcd on windows 7 : Vob Size problem?
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 24th Jan 2010, 14:58 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
svcd problem crashing with SP3
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th May 2008, 17:38 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
