I have been happily using Sefy's guide to ripping DVDs with Smart Ripper, DVD2AVI then TMPGEnc.
Until recently DVD2AVI has always produce a WAV file which works with TMPGenc. Suddenly it only produces an AC3 which TMPGenc will not use.
Any assistance would be appreciated.
Are you sure that in menu 'Audio' -> 'Dolby Digital' the 'Decode' option is checked instead of 'Demux' or 'Demux all' ?
Kitaro, your suggestion worked. VMT. I don't remember changing that setting but putting it back has solved my problem. Thanks again.
6 WAV files to one 5.1 AC3... need more help please..
By RogerTango in forum EditingReplies: 17Last Post: 13th Oct 2012, 09:00 -
Muxing .ac3 files?
By mrjust in forum AudioReplies: 2Last Post: 1st Jan 2011, 15:01 -
How to create M4V files w/AC3+AAC from M4V w/AC3 only??
By williamlondon in forum MacReplies: 4Last Post: 5th Oct 2010, 17:15 -
How to join ac3 files?
By X_Splinter in forum AudioReplies: 9Last Post: 30th May 2010, 10:10 -
AC3 (5.1 audio files) and PCM 96/24bit stereo audio files
By joannes in forum Authoring (DVD)Replies: 2Last Post: 9th Mar 2010, 16:48
