If I set up a dual boot and had one OS dedicated to capturing, would I notice any benefit than haveing one OS and capturing to an empty drive?
Mayby i got you wrong, but I'm using 2 OS (win ME and win XP). I use this since win ME uses VFW drivers and win XP uses VDM drivers....works very nice.
/wertigo -
If you are using two separate OS i.e. one for you main system and one to capture with this is a very good idea.
Keep you capture OS very lean i.e. no virus killer and only the programs you need to capture and basic drivers without all the extra utils bolted on. i.e. if you have a sound blaster just install the drivers not the extra crap which is on the CD.
Also if you can afford it buy a separate capture drive and capture to this. As soon as you have finished with your project remove it from your drive to your target media an start on your next with an empty drive.
Is upscaling really worth it?
By bobbysafety in forum DVB / IPTVReplies: 20Last Post: 10th Dec 2010, 12:04 -
What do you think this pc is worth....
By lordhutt in forum ComputerReplies: 3Last Post: 3rd Nov 2010, 08:00 -
dvdfab worth the $40?
By glockjs in forum DVD RippingReplies: 30Last Post: 25th Jan 2008, 06:28 -
Is the Matrox RT.X2 worth it?
By shockaholic in forum EditingReplies: 1Last Post: 22nd Jul 2007, 15:31 -
XP Media worth it?
By 123fish123 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jun 2007, 03:00
