Hi all. I will be brief.
I followed the procedure to convert divx to vcd extracting the audio with VirtualDub to a separate file etc.. When I make the movie with TMPEgenc using the video and the created audio from Virtualdub (even playing the wav by itself) the audio is poor.
The video is excelent and the music and the effects are ok but the dialogs are very low. Any suggestions how to correct this?
TIA
JW
If you mean Poor as in low volume then in TMPGE go to :
Setting > Audio > Check Audio Edit box > and set volume for 2 or 300% or more higher etc"Today is only yesterdays tomorrow" -
Thanks Wee for the tip,
Just for the information of others and after spending lots of hours trying to solve the problem, I found the root of the problem in the Divx movie, when you extract with VirtualDub the sound I had to do it in mono instead of stereo. Stereo was always giving me the same results but in mono (and increasing the volume as you suggested) did the trick, although the final output was a bit hissi.
Poor Audio: Effects Loud, Dialog too Soft
By stormdragon in forum Newbie / General discussionsReplies: 4Last Post: 25th Sep 2011, 20:02 -
Audio quality very poor in 360p...but only on some vids. Help please!
By amb in forum Video Streaming DownloadingReplies: 0Last Post: 19th Sep 2010, 15:06 -
Poor VHS or Poor VCR?
By ryangarfield in forum RestorationReplies: 10Last Post: 7th Jun 2010, 07:34 -
audio quality poor on ripped movie DVDs
By JohnnyBob in forum Newbie / General discussionsReplies: 2Last Post: 9th Aug 2009, 19:01 -
Copy DVD with ConvertXtoDVD and audio speech very poor.
By swog in forum DVD RippingReplies: 2Last Post: 24th Sep 2008, 17:12
