1st question: how do you make SVCD karaoke from DVD. I know how to do VCD but I think SVCD will be better. I found a topic on that and some one was refering to use DVD2SVCD to do it, unfortunately I wasn't able to find the guide.
2nd question: Why is the SVCD using VCDeasy not able to play on my computer. I used PowerDVD to play the MPEG2 file and it will load, but the movie is very jerky. But it will play fine on my DVD player without any problem, plus I was able to fastfowar and rewind too. While if I burn the MPEG2 file with Nero I will have problem fastfowarding on the DVD player but it will play real smooth on the computer.
Thank you in advance for all your helps![]()
I dont even mess with the computer and all the problems when trying to make VCDs.
Get a stand alone VCD or DVD recorder. Its easier and would save you a lot of time!
The Terapin VCD Recorder
WWW.VCD-TRADING.COM
New VCD, DVD, VHS Trading site.
Join up and start Trading Today!
Couple of Questions re footage.
By Lensmeister in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2012, 16:44 -
a couple of sub questions
By Kanyeeeze in forum SubtitleReplies: 1Last Post: 1st May 2008, 17:03 -
a couple of questions ..
By ZaYoOoD in forum AudioReplies: 6Last Post: 7th Mar 2008, 14:21 -
Common questions and answers.
By Faustus in forum DVD RippingReplies: 31Last Post: 27th Feb 2008, 06:21 -
couple questions
By mainegate in forum ffmpegX general discussionReplies: 2Last Post: 31st Aug 2007, 11:22
