When I create a VCD using Easy CD Creator 5 platinum I find that when I open the VCD I have several files that I dont understand. In order they are:- CDDA,CDI,KARAOKE,MPEGAV,SEGMENT,VCD.
In MPEGA I find the VCD file i created as a DAT file and in VCD i find these "Entries,Info,Lot,PSD" all have theproperties listed as VCD files unknowen applications.Can someone explain them
when you burn a vcd, the burner app must format it to fit the philips vcd standard, and hence all the folders and such. if you didn't have these, sure you could play it on your comp by manually choosing the mpg/avseqxx.dat, but it wouldn't be able to to play in a vcd/dvd player.
Okay so why does my video on the cd end up as"music01" and can I edit it somewhere along the line to have a different title or one that I can identify it by.
If you are interested what the individual directories and files are there for, I suggest visiting
http://www.cdrinfo.com/articles/videocd/page11.shtml
Technical Specification: Structure of VCD
<font size=-1>[ This Message was edited by: aldus4 on 2001-08-03 04:28:43 ]</font> -
if you have a music01.dat in the mpegav directory, i think only cequadrat winoncd does that? not sure. i'm guessing that's what vcd app you use to burn.
no, you can't edit it to change the filename.
VCD with SWF files
By justdoit in forum Authoring (VCD/SVCD)Replies: 14Last Post: 28th Dec 2011, 21:45 -
890619 - convert TS to VCD compatible files.
By hamidi2 in forum VCDEasy GeneralReplies: 2Last Post: 9th Sep 2010, 18:21 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 07:50 -
Author VCD files in a to DVD Disc
By akakiami in forum Authoring (DVD)Replies: 6Last Post: 5th Jan 2009, 06:22 -
Newbie question about VCD files for CD-ROM
By donn in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2008, 18:37
