I went dvd2dvdr and followed the instruction. I used smartripper to extract the correct vob files with ifo. I changed all output files to the same name. I used ReMPEG2 to encode the file.
I downloaded SpruceUp 1.1 trial to create a menu. In the movie tab,, I right click to import the m2v file. However, an error keeps popping up when I select the m2v file (movie Tab) from the Spruce-It. The error msg states that
"Temporal Reference in GOP #2387 (Zero-based_ are out of sequence (0xc10b000a)
What is this error and how can I fix and get to next and final step, which is to burn my first dvdr.
Thanks,
Rage
I just had the same thing happen to me. Let me know if you ever figured this out. Thanks..
I acutally used SVCD2DVDMPG+ to create the elementary streams for use in SpruceUP. Never re-encoded and didn't use ReMPEG. Orignal MPEG file was created using ULead DVD Movie Factory. I'll try TMPEng and BeSweet to demultiplex and resample, and see if I get the same result. If I don't, then the problem must be with SVCD2DVDMPG+. Any other thoughts?
Problem must be in SVCD2DVDMPG+. When I demuxed with TMPGEnc, problem went away. Could it be the pan-and-scan fix that causing the problem? I hope not, that's the main reason I decided to try SVCD2DVDMPG+.
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
Transform .m2v +. wav to full MPEG-2 dvd spec file?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 14th Oct 2011, 08:13 -
.m2v outputs from ffmpegX won't compile in DVD-SP 4 (internal muxer error)
By bbartley9 in forum ffmpegX general discussionReplies: 4Last Post: 21st Aug 2010, 03:57 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08
