i tryed dubdvd so i could convert straight from dvd to svcd like it said it could do but every time i press copy it says their is no blank disk in my cd writter when i know their is is their any other software which will do the same ? coz i can not rip to my hard drive as its only a 6 gig
thanks 4 any advise
well you can try DVDx it werks exactly like Dub-DVD but better but the mpeg file wil be saved on your hard drive but it wouldnt take up much space as an averge 2 hours movie willl be less then 950 megs if encoded with the standard settings but i must advise DVDx isnt the ideal quality encoder but its perfectly great but if you want a better Quality you might want to frameserve to TMPGEnc...this is possible with a few more tools
thanx 4 the advice what other tools would i need to make it a good quailty
as i am new to ripping ?
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
Ripping Saw 6 (Saw VI) dvd, HELP!!!
By diluvian8 in forum DVD RippingReplies: 5Last Post: 27th Jan 2010, 22:45 -
Ripping a DVD
By andreltr in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2009, 09:29 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 09:22 -
HD DVD Ripping
By joco200 in forum Newbie / General discussionsReplies: 3Last Post: 21st Jun 2007, 15:14
