Is there any way of converting a "wmv" clip to mpeg? I've looked all over the web and... I am stumped.
These clips play OK in Windows Media player (albeit with some hiccups) but are not "recognized" in any conversion program.
Thanks for any tips.
Thanks. However, I used that TMPGen program and it didn't recognize the .wmv file.
It DOES, however, play fine with Windows Media Player. Am I missing a step here?
Thanks for your help! -
You can do the Graphedt method - and go from wmv to high bitrate divx then to mpeg -- or wmv to uncompressed avi (very big file) and then convert to mepg in TMPGEnc
see this link: http://www.bath.ac.uk/~ma9sjb/dvd/asf2avi.htm
asf / wmv it doesnt matter it's the same method for graphedt
or you cna put the wmv directly into TMPGEnc -- not ALWAYS possible but I get it done - go to options->environmental settings->vfapi plugins-> and set your Direct Show filter to 0 (zero) then try to open it ... if it still doesnt work.
create the full path to your wmv (ex: c:\video files\test.wmv) and put that directly into tmpgenc for both the audio and video then close TMPGEnc and re-open it --- that FORCE sometimes does the trick
good luck -- you can do it with graphedt for sure - but it's just not very user friendlyyour pal,
Stinky -
I can anticpate the next question
I got Graphedt off of either http://www.divx-digest.com/ or http://nickyguides.digital-digest.com/
it's up to you to find the link
sorry
your pal,
Stinky
Guidance to create either a .wmv or a mpeg
By herscht in forum Newbie / General discussionsReplies: 3Last Post: 26th Feb 2012, 00:46 -
Convert mpeg-2 to wmv
By king71 in forum Video ConversionReplies: 2Last Post: 25th Oct 2010, 03:26 -
MPEG Streamclip / Converted WMV to MPEG-4 but only got the audio? Help me.
By aka_director in forum Video ConversionReplies: 0Last Post: 3rd Oct 2010, 22:24 -
Deinterlacing when going from MPEG-2 to WMV
By courtneye in forum Video ConversionReplies: 1Last Post: 9th Jul 2010, 09:24 -
WMV to MPEG gives error
By tommm in forum ffmpegX general discussionReplies: 0Last Post: 21st Dec 2007, 14:46
