Hello, was wondeing what patch, version, or differnt program i could use with windows XP because when ever i start DVD2AVI v1.86 it always crashes. I bet this isnt a new issue but i couldnt find any when i searched the posts.
Thanks to any who reply
umm you might want to try the orignal made by Loli J. version 1.86 is a fixed version but i really dont like it..i perfer 1.76 you may still download version 1.76 here at www.doom9.org
BUMP
Thanks for replying pinoy2201. I have tried both thoes versions and they both crash
Somone has got to have a solution to this issue? Am i the only one who is trying to "make back up copys" with Windows XP? -
I use xp and it works fine. I have trouble with tmpgenc sometimes crashing, somedays it will load d2v files and others it says unsupported file format!!. Can't load ac3 file in audio either.
Don't know the prob but I use DVD2AVI and Tmpgenc on WinXP and they both work fine.
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 22:53 -
K-lite issue then mp4 issue
By Arch3type in forum Software PlayingReplies: 0Last Post: 15th Dec 2010, 10:57 -
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 19th Aug 2010, 23:11 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 09:47 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38
