I have used WinRar to unpack .rar files from Blade 2 and when I went to burn it I saw that there was a .bin file and .cue file.
I read about them and have trying to put this thing together for a while with no success.
I have tried to use CDRwin but it does not recognize my CD Burner(BurnProof).
I have also tried to use FireBurner but cannot seem to get it to work.
This is the first time I've worked with the .bin/.cue stuff....HELP!![]()
Results 1 to 9 of 9
I had the same troubles but i solved it. This is how. The best is to install Daemon Tools at www.deamon-tools.org. This program create a virtual CD-rom drive. Now you can load the cue.file into the virtual cd-rom. And the great thing is, you can first control the file by opening the virtual cd-rom in any DVD or VCD software player!!! Then start Nero or any other burn software and just choose Copy Cd. Then copy the content of the virtual CD to the real CD-R(W). Good luck
Mario -
if it does not recognized your cd burner and you run win2k or xp it's probally due to the fact that there is no native aspi layer present in either OS, so you need to install one ( force aspi ro aspi 4.6 ), or you cn let Nero ( current is 5.5.8.2 ) burn it by selecting Burn Image -- File and hen selecting the cue sheet, and then burning.
Also the latest Nero version does it very easily w/o using the virtual drive. I couldnt get Fireburner or CDRWin to work either.
i just got the .bin file.. and used iso buster... extracted but when i tried playing in wmp ..doenst recognize...
do i just burn it to vcd? -
Thanks Kevin!
PlayinDirty101 I have been using VCDgear and it has made my life easier
I use it to change my bin/cue files to mpeg so that I may burn them to VCD or SVCD format depnding on the file type. -
Use Nero. Make sure you have "overburn" checked within your settings. Go to File, Burn Image, and select the specific cue file. This will burn your bin file. Now, make sure you change the burn setting to "disc at once" and you'll be on your way. I was able to fit a 815 MB SVCD onto a 700 MB cd this way with no problems. Let me know how it goes for everyone.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 00:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
