hi ppl
i need alittle help with making a vcd . i'm trying to encode THE ONE , i used vdub to encode the audio to wav, now i'm trying ti use tmpgenc to encode the video and join the audio . when i did it , i preveiwed it and i didn't get any sound only saw the movie . can someone help me with this problem .
i tried the search topics but couldn't find anything to help me .
thank you
assuming you had an AVi or DivX originally,did you play that ok with audio?
When you extracted the audio with Virtualdub did you save it as a WAV as per: http://www.vcdhelp.com/virtualdubaudio.htm
Then using TMPGE use resulting WAV as audio source?
Run TMPGE for a minute or two ...stop the encoding and view the short file...audio still there?"Today is only yesterdays tomorrow" -
Hey!! I have the same problem, but the movie is citizen kane, and yes the source file is avi, and yes when I play the movie .avi in my computer the sound is ok, but when I´ve converted it to vcd the sound is not there. The thing is that I had converted a lot of movies (avi to vcd or svcd) and this is the first time that I have a problem with the audio.
any idea? -
Hey so do I. I've encoded episode 9 of season 8 of Friends a gazillion of times and still... there's no sound. Not only that, but for some reason, it encodes the video twice so it becomes twice the size.
What's up with that?!
Twice the video, zero sound.
VirtualDub doesn't play audio in preview
By Sebastian2011 in forum EditingReplies: 20Last Post: 19th Mar 2012, 04:33 -
Half of DVD Doesn't Play
By theWallflower in forum Authoring (DVD)Replies: 19Last Post: 20th Dec 2011, 22:08 -
Why WMP doesn't play DTS audio (MKV, M2TS files) ?
By mahogany in forum Software PlayingReplies: 2Last Post: 11th Dec 2010, 14:45 -
Audio doesn't play in AVI files, although AC3 codec IS installed
By DVantrease in forum Software PlayingReplies: 2Last Post: 16th Jan 2009, 17:57 -
DVD+R Doesn't play after halfway through
By cfresh13 in forum DVD RippingReplies: 9Last Post: 21st Mar 2008, 19:28
