I use tmpgenc and Virtual Dub for alot of my video editing. I have noticed and used with great effect the temporal Smoother option with in Virtualdub and was wondering if such a filter existed for tmpgenc.
I think the only way you can use the Temporal Smoother or Temporal Cleaner is to Frameserve into TMPGEnc from VirtualDub.
I do that a lot -- I have two pretty good Equalize filters that will "brighten up" darker movies and normalize the colors.... those are good ones also -- but yea only when I frameserve into TMPGEnc from VirtualDub
so the answer is yes you can use them in TMPGEnc - put your source video in VirtualDub - set your filters and then frameserve into TMPGEnc
if you don't know how to frameserve it's very simple - see the links in the FAQyour pal,
Stinky
buffering stream for smoother playback
By pensioner in forum Video Streaming DownloadingReplies: 1Last Post: 26th Sep 2011, 08:25 -
AC3 codec/filter with virtual dub and TMPGEnc
By buzzsaw in forum Newbie / General discussionsReplies: 16Last Post: 24th Apr 2009, 18:47 -
Tips On Optimizing VLC for Smoother Playback in OS X???
By Danteism in forum MacReplies: 9Last Post: 24th Jan 2009, 04:27 -
(Smoother) Cropping / Blending with Audacity
By Seeker47 in forum AudioReplies: 2Last Post: 3rd May 2008, 18:05 -
How to emulate the Video Noise filter in premiere pro on TMPGENC Express 4?
By hanugro in forum RestorationReplies: 5Last Post: 25th May 2007, 05:11
