Here is the situation..
I have been using verbatims DVD-R's and have had no major problems, except for a few artifacts here and there.
I recently got some cheaper media (stupid mistake) that I am having quite a bit of problems with. My question relates to duplicating DVD's.
I have a DSR DVD duplicator tower (with 4 bays). If I use the verbatims to burn the master and then use the cheaper media as the ones being duplicated to, will I have the same problems as before with the cheaper media? I didn't know if maybe the duplicater is simply copying the .iso file or something.
Thanks.
Cheap media is cheap media no matter what you put in in... if it has trouble burning 1 on 1 it will also in your duplicator. If I'm making disk for others to use I would personally use Apple disk.
how to block people from duplicating my external hardrive
By ltdg in forum ComputerReplies: 39Last Post: 21st Feb 2013, 06:44 -
Duplicating DVD-9 - more duds than DVD-5?
By sdsumike619 in forum Authoring (DVD)Replies: 4Last Post: 12th Mar 2008, 13:03 -
Decimating exactly to 25 from 29.97 (PAL-sourced - by duplicating frames)
By Alex_ander in forum RestorationReplies: 4Last Post: 21st Sep 2007, 04:02 -
DVDLab Pro: non-working links and duplicating item in play list
By daamon in forum Authoring (DVD)Replies: 6Last Post: 25th Jul 2007, 06:12 -
Duplicating people using adobe premier pro 2
By vipertongn in forum EditingReplies: 20Last Post: 12th Jul 2007, 01:07
