  1. need help ripped dvd encoded it and burnt it onto 2 cds when playing the picture and sound are perfect except as soon as there is movment small horizontal lines appear around the moving object.
    i used smartripper to rip.
    dvd2avi to encode first
    then tmpgenc next
    then ifilm to cut the mpeg before using nero to burn
    any help would be great
    thanx
  2. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    did you try to select "deinterlacing" in TMPGEnc?
    The Dutchman
  3. i didnt but i noticed that further up from the filter list it said that it was non-interlased (progressive).
    do you know what that means
    thanx
  4. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    If you are referring to the source input:
    this is a selectable field, you have to define what the source is. Just try your source as interlaced, and select the de-interlace filter.
    Now encode for 5 mins and check if you mpeg file looks okay.
    The Dutchman
