I had version 1.09 and she was working fine, but I have switched to the
newer 1.1.1 and I am getting wierd chapter problems as well as warnings
when I am making the image.
Here is an example of the messages I am getting
mpeg user scan data: one or more BCD fields out of range for 'previous_I_offset': [00:02.2d]
mpeg user scan data: one or more BCD fields out of range for 'backward_I_offset': [00:06.2e]
mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:02.3e]
mpeg user scan data: one or more BCD fields out of range for 'backward_I_offset': [00:08.3e]
The other problem is that even when I do get proper chapters, when
I use the next and previous buttons to skip between them, the audio
and video are out of sync. They eventually resync in a couple seconds,
but this has never happened before. Should I just go back to my
original version or is there a setting I need to fix.
(I already relaxed the APS constraints for chapter entry points)
Can anyone fix my stupidity ?
Weasyl![]()
Results 1 to 1 of 1
MKV chapter file extraction problems
By ikarishinji41 in forum EditingReplies: 1Last Post: 22nd Mar 2010, 11:03 -
Super C Problems - Recent Version
By PowerFalcon in forum Video ConversionReplies: 6Last Post: 18th Jun 2009, 19:04 -
DVDLab Pro output Chapter problems
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 4Last Post: 9th Mar 2009, 20:38 -
VCD Easy
By kshavo in forum Authoring (VCD/SVCD)Replies: 10Last Post: 12th Feb 2008, 14:43 -
new version problems
By dickdb in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 4th Oct 2007, 11:15
