Results 1 to 15 of 15
    May 2002
    Hi !
    Can a couple of people please tell me their encoding times for tmpeg. ie converting a two hour movie or a 45-60 minute episode like x files or friends from a ripped dvd to vcd or svcd. Please if possible tell me if you are using a dual or single processor and what spec.
    I have an amd k6-2 550 with 256MB RAM. I'm planning on upgrading. It takes me overnight just to do a single 45 minutes x files episode.
    thanks in advance !
    Dec 2001
    USA
    It take about 2hrs to encode a DVD rip of 1hr 30min movie. i have AMD Athlon Xp 2000 +. This is for VCD. I have read when doing VBR 2 pass it will take twice as long as 1 pass CBR. I also do batch converting, doing several movies over night.
    May the force be with you.
  3. well on my P3 1.0ghz it use to take me like 4 hours for a 2 hours movie but i just got a Amd Athlon Xp +170 and it akes me like 2-3 hours
  4. Am I doing something different here? I like to max out all the quality settings (except Motion Search Precision, unless it needs it), because I like my VCDs to look and sound good, but my VCDs take about 16 hours for a 2 hour movie. I encode from 520 x something DivX files to PAL VCD (MPEG-1), and I have a P4 1.5GHz with 512MB ram and a huge hard drive, so no space problems.
    Is there an option I've missed which says "Don't go so sloooowwww that encoding must take place overnight", or is it just because I am maxing the quality out?
    Thanks for any advice!
    CobraDMX
  5. yup your problem is your maxing everything! i usualy make everything at normal settings but i usualy tweak things abit more and plus i encode at a Motion Search At a High Setting not Highest setting has the highest setting give the same quality as high setting but it tke twice as long....i suggest try to encode at a normal settings
  6. Originally Posted by ha13may
    Hi !
    thanks in advance !
    Approximately 3.5 hours with my dual P-III 850 with 512MB ram. Settings are two pass VBR with interlace filter on and for the audio I use tool lame and ssrc.
    For the same movie and the same settings my P6 1.6a with 512 DDR would take approximately 3 hours so not much of a gain for me. I intend to get the dual AMD machine soon and then I am sure there will be a significant difference.
  7. Originally Posted by aruprc16
    For the same movie and the same settings my P6 1.6.
    Never heard there was a Pentium 6?
  8. Recently build 2 P4a (1.6G & 1.8G) systems and 1 Athlon XP 1800+ system. The encoding time in TMPGEnc do not differ by much. 1800+ and P4A 1.8G take around the same time to encode.
    It also depends on your converison scenario. Some claims to encode 2-3x of video time, you need to check the source and target resolution and format. This can be very misleading. If you convert from a DV/DVD source and encode to PAL/NTSC VCD format, it will take a very long time no matter what processor you use. Of course, the faster the better but it won't be anywhere closed to real time encoding.
    Tips: Prevent resizing your preview window size helps in encoding time. Also use multi-threading feature if you have a faster processor although you don't have a dual processor system. Setting to highest priority when active in W2K/XP helps. Video prefeteching is NOT recommended as it might eat up more bus traffic and display erratic remaining time...
    Hope this helps...
  9. encoding times all from ripped dvd sources
    svcd 480 x 576 15 fps at vbr ~2200 (500 - 6500)
    dvdr 720 x 576 12 fps at vbr ~2500 (500 - 9500)
    on svcd i work with 2 passes
    on dvdr i work with 3 passes
    all encoded using avisynth/cce (svcd simple resize or bicubic resize)
    mashine im running on is PIII/750 512mb ram 20/80gig hd´s
    all encoding from 1 drive to other for a bit better performance
    thats about it
  10. ups, forgot something
    all encoding without audio
    audio sep. with toolame about 20min for 2h movie
    then depends
    svcd have to multiplex video/audio
    so takes another 5-10 min each cd
  11. Member holistic's Avatar
    May 2001
    here & there
    Download VCD and full ISO of games Here
    Being a mod, i knew you were clean but when i saw that i almost fell off my chair . Funny 1 P
  12. 63 minute video -> tmpgenc VCD + soften block noise = 30 minutes
    63 minute video -> virtualdub + crop and resize + smartsmoother -> tmpgenc VCD + soften block noise = 98 minutes.
    I'm using a dual athlon MP 1600+. My source is a huffy encoded AVI @ 352x240. I cap a 1 hour tv show with 1 minuted pre-roll and 2 minutes post-roll, hence 63 minutes.
    Going the DVD2AVI route slows it down a bit, but I almost never make dvd rips so I couldn't tell you the encode times.
  13. I'm also new to this so I'm probably doing something wrong..
    so far about for a 1 hour movie:
    10 hrs with TMPG in CQ mode
    10 hrs with CCE in very good quality mode
    5-6 hrs with CCE in default mode
    using DVD2SVCD , K7-900, 256 MB, 98SE
  14. SURVEY: How about SVCD?
    Example.. 45 minute show, encoded to MPG2 for an SVCD.
    What programs do you use and what settings?
  15. for a great quality dvd -> 2 svcd movie backup, it takes me a good 8 hours per dvd on average. i use tmpgenc using 2 pass VBR in high quality motion search precision and toolame and SSRC as external audio plugins. definitely worth the wait!
