Hi,
I'll keep it to the essentials only !
I have a divx movie that plays perfectly in Windows Media Player and Powerdvd. When I covert to VCD with Tmpgenc (latest) (yes, I am stripping out the uncompressed WAV first), then play it on my standalone DVD player, the audio and video go in and out of sync quite often.. BUT - this is visibly being caused by the video slowing down and then speeding up (the audio sounds fine). It will go out of sync for about 30 secs then correct itself !
Any clues where to start poking ?
Thanks.
I hope that movieŽs not be THE MATRIX, because I have the same problem. Actually IŽm working on it right now, I think I could to solve it.
If the thing is fixed IŽll give you the solution.
Cross your fingers!!!
Luck! -
maybe slow down the enoding process or use 2 pass
"Today is only yesterdays tomorrow"
DivX HiQ slows down scrolling in Internet Explorer 8 & 9
By KTH in forum ComputerReplies: 1Last Post: 6th Apr 2011, 11:39 -
Audio & video out of sync
By gaboone in forum Newbie / General discussionsReplies: 1Last Post: 25th Mar 2011, 21:21 -
Video & Audio is out of sync after muxing
By Spettro in forum EditingReplies: 2Last Post: 2nd Dec 2010, 11:11 -
Audio & Video Out-of-Sync
By Bonie81 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Oct 2010, 15:13 -
Audio & Video In Sync
By marioval in forum Authoring (DVD)Replies: 22Last Post: 22nd Oct 2007, 18:13
