  1. Hello everybody, I'm very new at making VCDs, and I need your help. I was making a music VCD concert, with about 10 tracks (same quality, same rip and everything) from mpeg files using Roxio Easy CD Creator 5.0. It recorded fine until I played it on my DVD player.
    I mean, it played fine, I watched all the first 5 tracks normally, with great quality and everything. When the 5th track ended, it paused for a while and skipped all the way to the 9th track. The 6th, 7th and 8th tracks were added at the end of the 9th track as part of the same track.
    Can anybody help me with what's wrong?
    Thank you
    Caio
  2. You burned it then added more maybe?
    A Video CD or DVD has to be finalized in one shot to work in standalone players. Use "Finalize" or "Disc at Once" mode.
    If you want to play around use a CD-RW. Erase it between test burns.
