Hi,
I am pretty new to this capture/convert lark, but I seem to be doing OK.
I have a problem though. I have captured a Videotape as an AVI file using VirtualDub and converted it to mpg1 using TMPGenc. When I burned it to VCD though and played it on my home DVD, the sound stops about 3 minutes into the VCD, only to come back about 30 minutes later.
Since, I have checked the mpeg file in Windows and it does the same (obviously - i should of check b4 burning).
I have tried this a few times and always get Audio issues. Is there a fail-safe way to convert AVI-MPG at a reasonable qualty and with all audio intact?!
Please help if you can,
Rgds, Paul.
I extract the audio using Vdub first before I encode a capture wit TMPGenc.
Use the following guide to extract the audio.
www.vcdhelp.com/divxtovcd.htm#audioMay the force be with you.
newbie Q about cutting data from flv
By edurbrow in forum Newbie / General discussionsReplies: 5Last Post: 11th Jun 2011, 20:09 -
Cutting 20 ms audio frames
By TrupsT in forum AudioReplies: 1Last Post: 1st Sep 2008, 00:21 -
Mini-DV audio cutting out
By sonicdeth in forum Video ConversionReplies: 2Last Post: 7th May 2008, 19:03 -
Cutting File size through muxing HD Audio
By Mastablastacious in forum EditingReplies: 1Last Post: 4th Feb 2008, 03:18 -
Audio cutting question/help
By cowboysroy31 in forum AudioReplies: 0Last Post: 26th Dec 2007, 22:57
