  1. OK, firstly sorry if this is on this site somewhere I have looked but want to know the best result.
    I have downloaded several Friends episodes, they are all AVI files. I want to put them on to cd in such a way that they will play on my DVD player (which is VCD compatible etc). I have got as far as converting a couple of episodes (using TMPENC - although I am not exactly sure how to do it correctly) and burning them just as a data disc - they played, but no fast-forward or anything, you had to watch the whole thing in one go. I have now encoded a few more episodes, but when i try to burn them (Using Nero 5.5.5.1) I keep getting an error message.
    What am I doing wrong? - or what would be better software to use?
    THX in advance for any help with this.
    Mar 2002
    canada
    try using vcdeasy which you can find in the tools section. i have found that when i tried burning as data,they did not work at all.
  3. Thnx, I will try it and let you know.
  4. I tryed, but the links are dead.
    When you click on the vcdeasy link, it goes to the VCDeasy site, but none of the download links on that site work!!
    Any other ideas???????
  5. I tryed, but the links are dead.
    Dec 2001
    USA
    What is the error message?
    May the force be with you.
  7. I can't remember exactly - but now I have a new problem - I have recently put XP onto my machine - and it doesn't seem to recognize my CD-R Drive - Mitsumi 4801TE - weell it recognizes it but not as a burner just a CD-ROM I think - I can't find the driver anywhere, anby ideas anyone?
