  1. Hi!
    I have a Pinnacle PCTV Pro Card. OS: Windows XP Pro.
    I have installed the newest PCTV Vision software, and updated it with the patch (downloaded from www.pinnaclesys.de).
    What resolution can I capture in with this card?
    Before I was able to capture in 384x288. Now I can't choose any higher than 352x288. I use AVI_IO or Virtual Dub to capture.
    What can I do?
    Also I wonder if it's possible to capture any higher than 384x288 with this card?
    Computer:
    PIII 800mhz, 384MB, 40GB 7200RPM WD and 120GB 7200RPM WD.
    Thanks!
  2. I have a pctv card and had problems with the latest version 5 XP drivers, they wouldnt work with virtualdub even with all the patches and wrappers so i gave up with them and reverted back to version 4 drivers which work ok.
  3. Or alternatively, if you want WDM drivers, check out http://btwincap.sourceforge.net
    However they will not allow you to use the PCTV application, you'll have to get a third party app for that.
