I need a little help to cut some credits off an mpeg file so that i can fit it onto a disc.
What programs do i need and is it easy?
Cheers.
Doh Doh Doh!!!
Read the how to edit guides
I always use tmpgenc settings>advanced>source range
Never have problems -
Yeah me too but ive alrealy made the mpeg and i dont have time to waste on making it again.
Doh Doh Doh!!! -
The Cut/join section in TMPGE will not reencode your MPEG it justs cuts it off, might take you 10 minutes to get it all done, just depends on how fast your computer is, my AMD 1600+ only takes a minute or 2 to cut scenes.
Next time edit before encoding. Use a bitrate calculator to set bitrate so it will fit on cd
cutting an mp4
By pike8 in forum EditingReplies: 3Last Post: 19th Nov 2010, 16:57 -
video cutting
By Mr anderson in forum EditingReplies: 2Last Post: 21st Oct 2010, 14:42 -
[FR] Cutting TS Help Me Please
By KERNEL32 in forum EditingReplies: 5Last Post: 26th Feb 2010, 13:38 -
cutting an MPEG
By php111 in forum EditingReplies: 3Last Post: 7th Jan 2008, 08:32 -
Cutting Out
By OG24 in forum Newbie / General discussionsReplies: 2Last Post: 12th Aug 2007, 18:55
