I have just purchased a laptop with a firewire port. I intend buying a digital camcorder to make use of this port. I`ve just been reading on this forum that certain models of camcorder will enable you to pass thru an analogue signal and capture via firewire.
My question is, at what resolution/framerate can you capture the converted analogue signal, are you stuck with the standard dv resolution or can you decrease resolution/framerate to decrease file sze?
cheers.
ps whats the cheapest (uk) pal dv cam that allows you to the passthru.
The camera converts the Analog signal into standard DV format.
It is a HARDWARE capture so there are no adjustments that you can make. -
ok Thanks.
BTW what is the resolution of dv , and what format is it in when passed thru the firewire?
Cheers
Selecting passthru audio in MPC HC rather than the prologic
By skinney6 in forum AudioReplies: 2Last Post: 26th Jan 2012, 11:37 -
can't figure out passthru with JVC GR-DVL820U
By MajorMalfunkshun in forum Capturing and VCRReplies: 1Last Post: 3rd Jul 2009, 00:50 -
Capture analogue (eg. VHS, analogue camcorder) - AVI or MPEG?
By ManUtdFans in forum Capturing and VCRReplies: 3Last Post: 18th Jan 2009, 18:29 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57 -
Analogue Capture
By Sonnyt in forum Capturing and VCRReplies: 3Last Post: 26th Mar 2008, 19:49
