on my DVD player? Yes, I've checked, VCDs work on my model. But I can't figure out which files I use for VCD. I've created lots of MPGs with TMPGEnc, but I can't figure it out. Do I just burn them with my regular burning program? Or do I need to convert to *.bin?
Thanks,
sachi
Might be an idea to look through some of the "How to's" on the left.
Mike -
I did... ok i'm bad at searching for things... but you really don't know the answer??
well might as well give it a try...
Sachi -
http://www.vcdhelp.com/author.htm
pick a program and go for it. -
Thanks, but I already tried those...
I can't use VCDeasy because my burner is too low model.
I can't use Nero because I get *.nrc files and I have no idea what to do with the thing.
I can't use VCDImager GUI because i get *.bin files and don't you need Nero to convert those?
Kind of confusing... anyway, I just attempted burning the *.mpg and it worked, except i can't fastforward and use chapters..
I really apologize for being so newbie.
Sachi
Can I burn a .mpg file to a DVD
By robrpb in forum Video ConversionReplies: 4Last Post: 8th Sep 2010, 20:56 -
How Can I burn a 90 min data CDR Image to HD Folder
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2008, 19:48 -
Burn MPG file onto DVD
By geek2330 in forum Newbie / General discussionsReplies: 15Last Post: 2nd Oct 2007, 08:51 -
Is it better to burn a VIDEO_TS folder or a MPG file?
By geek2330 in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2007, 16:54 -
Trying to burn a mpg video file to DVD
By bhxtyrant in forum Authoring (DVD)Replies: 8Last Post: 11th May 2007, 14:22
