do via chipsets still suck? it seems that the best deals and the best features for amd motherboards all have via chipsets.
thanks
Results 1 to 16 of 16
THIS IS HARDCORE
That depends on what CPU you are using and what RAM.
Intel with RDRAM, it got to be intel.
Intel with DDR, SIS
AMD with DDR, VIA or SIS they perform just as good.
my opinion only -
no via is find i just set my cousin up with a xp1800+ ,he sais it took 16 hours to do his avi-mpg conversion now it takes 53 minutes for the same file
no via is fine i just set my cousin up with a xp1800+ ,he sais it took 16 hours to do his avi-mpg conversion now it takes 53 minutes for the same file
VIA is not beautiful, AMD ATHLON XP IS!!!!!!
I have a Athlon XP 1700+ @ 1800+ with 256 Mb RAM PC133 and I KICKED a P4 1.7 MHz 256 Mb DDR when converting DVD -> SVCD (backup) with same setting, same movie!
PS: VIA helps of course! 8) -
so there's no reason i shouldn't get a motherboard that uses a via chipset then?
cooly-o. are those your system specs? do you ahve serious problems with your via chipset?
thanks ya'llTHIS IS HARDCORE -
For encoding I don't think there is a problem...
For capture some device makers say don't use VIA boards -
I have used VIA chipsets since the FIC VA503+ and have never had a single prob with their chipsets. I now use a FIC AD11 with a AMD 761 north bridge and a VIA VT686B I/O controller, Athlon XP 1700+, 256 MB DDR 2100 and it rocks. I rip, convert, remux or what have you with 98% success rate. I really recommend VIA
it seems that the motherboards with the most features all have via northbridge chipsets! does anyone know of problems with amdnorthbridge/via southbridge setups?
this is such a headache.THIS IS HARDCORE -
Originally Posted by statuspending
Those are my specs in my "Computer Details" tab. It's not a VIA chipset. It's a ALi MAGiK1 chipset. There all good chipsets as far as I know.
REF:
http://www.vr-zone.com/reviews/IWill/XP333-R/
per:
http://google.yahoo.com/bin/query?p=%2b%22iwill+xp333%22+%2bchipset&hc=0&hs=0 -
As long as you get a recent VIA chipset (e.g., KT266a), running the latest MoBo bios, and you download and install the latest (1)VIA Busmaster Filter Driver (from 4 in 1 drivers) and (2)VIA Busmaster Miniport driver, your MoBo should run pretty darn stable.
VIA Busmaster Filter Driver (from 4 in 1 drivers):
http://www.viaarena.com/?PageID=2
VIA Busmaster Miniport driver:
http://www.viaarena.com/?PageID=66
Comment:
When you start adding additional components (e.g., capture cards, multi-purpose video cards, etc.), the potential for problems will most likely increase. But this affects AMD as well as Intel MoBos, Via as well as other chipsets.
Practical Tip:
Generally, newer drivers are more stable and yield faster system performance. But if you experience no problems with your hardware and drivers, don't upgrade to newer drivers. -
i have actually just settled on my mobo
abit nv7-133r
raid
usb2.0
ac3/5.1 channel sound w/ optical out
lan
all onboard...it's sweet. and most importantly,
NO VIA CHIPSET!
woohoo! thanks for your help everyoneTHIS IS HARDCORE -
How much did you pay and from where? Also, tell us if it's all that it is cracked up to be. That's an Nforce MoBo right?
$81
www.qbitpc.com
damn thing won't support my voodoo3 though, so i need to upgrade my video card now...didn't wanna do that, but everything else about it looks golden.
thanks
i'll let ya know how it is when i get it.THIS IS HARDCORE
another example of why copyright laws suck
By deadrats in forum ComputerReplies: 10Last Post: 25th Oct 2009, 10:54 -
( COD4 ) Does the P90 Suck. Simple Yes Or No
By mikayd in forum Off topicReplies: 3Last Post: 27th Apr 2008, 00:05 -
Am I doing something wrong (or does YouTube suck?)
By Spaceboy88 in forum Newbie / General discussionsReplies: 5Last Post: 25th Aug 2007, 16:19 -
trying to suck Bjork
By poacher99 in forum Newbie / General discussionsReplies: 23Last Post: 9th Aug 2007, 12:37 -
Why does Safari suck so much?
By kevs in forum MacReplies: 69Last Post: 29th Jun 2007, 09:32
