Every time I use multi-pass VBR on CCE with DVD2SVCD I get an error on the encoding. "Video check-sum is different from that of previous pass" and the encoding fails. If I do one pass VBR it will complete but I want to do multipass VBR. If anyone can help it would be greatly appreciated.
Yes i too get the same error often on CCE, it has something to do with your video information file. It always happened to me when i used a presaved video information file. Try doing it all in one go and you might not get the error, however i had all sorts of other drama's with CCE's multipass VBR so i just used CBR, and still got good results.
Which patch, I couldn't find one ???
I found it, it fixes problems with Athlon processors and disables the checksum function. Cool, it works now !!!
Thanks for the help.
(PS I didn't find it at doom9 though, I found it in a cdrsoft video forum post, the patch was in german on some site in Germany. -
couldn't find it ..that's strange it's in the Q&A
http://forum.doom9.org/showthread.php?s=&threadid=21859
Q27: I get this strange Checksum error from CCE when it runs...
A: Please download this patch 15KB (Thank's ALI! for hosting)
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 14:25 -
cce video bitrate problem
By DSLGuy in forum Video ConversionReplies: 11Last Post: 16th Feb 2008, 13:53 -
CCE OPV
By name123 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 13:03 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27 -
CCE-SP2
By Belfour in forum DVD RippingReplies: 10Last Post: 29th Sep 2007, 20:47
