on disc one after multiplexing the mpg for a new svcd header the audio is now gone after about 18 minutes or so. i burned the svcd thinking everything was fine and deleted the original mpg file before catching this.... bad move i guess. could anyone tell me if this is fixable without having to download the complete file again? if someone would be so kind to help me with just the audio (over dsl connection) i'd be very grateful. thanks for any help of this.
doc
i'm on aol instant messenger tonight ( D0C R0BERT ) is my name. the 0's are zeros.
Hey!!!
Did you have the same problem with jumping sound every 10 sec???
I do and i cant figure it out... its on all 3 cd's
CaiZar -
no i don't have that, it just goes silent completely about half way through the movie on disc 1. do you have dsl or cable? if so i'll hook you up with the audio if someone helps me with disc 1.
take care,
dave
SOMEONE PLEASE HELP ME WITH THIS.
I had the same problem with spiderman. So i just took the mpeg-2 and used vidiomi to divx it then i used avi2vcd and decompressed the audio then used TMPEGenc and used the vcd converter in that, chose the divx file as the audio and the pci thing from which the avi2vcd made and converted it there.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 07:36 -
RipBot264 Audio Problem (no audio)
By fefalas in forum Video ConversionReplies: 9Last Post: 8th Apr 2011, 11:39 -
Help With Audio Problem please!
By heidilynn08 in forum AudioReplies: 3Last Post: 16th Dec 2010, 12:08 -
i have spiderman season 1-5 and its .avi. can i burn each season on dvd?
By dizzlenizzle87 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jun 2007, 01:23
