  1. i am trying to capture some old video tapes using a 3500 voodoo 3 card but can't seem to get it set up right.
    as it says drivers not found when i open premier but the drivers for the card are installed and work fine any idea's please
    thanks
  2. I also have a Voodoo 3 3500 card. Unfortunatly I do not use Premire.
    I've always used VirtualDub or the visualreality software that came with the card. Are you sure your using the latest drivers/visualreality software.
    http://voodoofiles.com has the latest files and tweak programs out there.
    I hope this helps you out, and let me know if you get it to work.
