this is what happen when I try to encode on tmpge. living in the states I use 44,100hz this usally happens on 48,000 hzs films.
when i install on virtualdub to split the audio and video i get the following.
VD has detected an improper vbr audio etc etc. If I split audio and install and install the movie in video and the wav in audio it is out of synch. Should I put a split video and wav in tmpge. Or is there a setting that will let me split audio without getting the improper vbr audio.
first post let's see what happens
if Vdub reports VBR audio stream (from a downloaded Divx I would guess), the use vdub with direct stream copy to extract this audio stream to a seperate file. Then use a tool that can handle VBR audio correctly, such as beSweet, to convert to uncompressed PCM wav file.
There is also a tool called decompress.exe (search on google for it) that will take your avifile and produce a copy but with uncompressed PCM audio. You can the process it as normal.
Either of these may solve your problems, let us know how you get on.
Toast "An error has occurred recompressing the video"
By trevytrev in forum MacReplies: 12Last Post: 25th Feb 2015, 16:47 -
a disk error occurred during a write operation
By SE14man in forum ComputerReplies: 8Last Post: 8th Nov 2011, 01:16 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 15:59 -
Sound is not decoded properly using the latest Quickplay v3.7
By pwangdel in forum Software PlayingReplies: 0Last Post: 8th Nov 2008, 09:38 -
FAVC 1.06 error - Unhandled exception has occurred in your application
By mcv2008 in forum Newbie / General discussionsReplies: 3Last Post: 17th Jun 2008, 14:15
