i am currently using Tinra for converting some
.ram files into .avi and untill now i haven't had any problems.
Problem: after conversion, i check the .avi file and the sound
is perfect, but the video looks like a slide show!?!?!?
it's not flowing video like the original .ram!!!
I have never had this problem before.
Could it be because the .ram file is copyrighted or something?
Any help would be appreciated!!
mot...
Given the fact that RAM/RM files are multi-bitrate and horribly encoded, what can you expect from a shitty format?
I know the format is shitty
but I really want these clips!
I have no idea what is wrong...
Tinra has never done this to me before.
mot... -
Hi, I was trying to use tinra to convert too...but I only get sound but no video. And I am using real player basic 8 too...so would u please tell me what is the problem?! thanks
(sorry that I can't help your problem) -
Ask on the TINRA forums.Originally Posted by musingsoftrust
http://guiguy.wminds.com/forums/viewforum.php?forum=5&0
As far as its concerned, ITS outdated IMHO to handle the new encoding of RM files for Real Video. Its based off of the REal Player G2 which has been out of date for 2 1/2 years. Do you have Real Player G2 installed? its the minimum requirements.
By MGadAllah in forum Video ConversionReplies: 1Last Post: 28th Jul 2011, 16:43 -
Problems copying .VRO files from DVD-RAM -- SOLVED!
By usually_quiet in forum DVD RippingReplies: 14Last Post: 2nd Jun 2011, 16:30 -
DVD-RAM to AVI.
By aliciac in forum Video ConversionReplies: 16Last Post: 1st Apr 2011, 14:29 -
.rm to .avi problems
By xNovaXx in forum ffmpegX general discussionReplies: 2Last Post: 21st Feb 2010, 19:54 -
Dynamic RAM preview off in Vegas, could it cause rendering problems?
By Srivas in forum EditingReplies: 0Last Post: 8th Dec 2007, 03:19
