I don't know how to add the vobsub filter in VirtualSub so I can be able to add the subtitles on my VCD. I've done as I read on the net: copy the vobsub.dll in Virtualdub and changed to vobsub.vdf
When I try to install the filter it newer shows in the "add filter" window..even so, if I try to load the vdf file I get the error message: "vobsub.vdf does not contain VirtualDub filters"
How to do?
Thks
Akaiu
Probably you noticed, that vobsub comes with an installer. Check "vobsub for VD" when when you install vobsub. Renaming the .dll to .vdf does not work with the newer versions.
Truman , I've tried with the instaler but always says that the path for Virtual dub is not correct...I did removed and instaled VD in several places..same report....
Problem when using Deshaker Virtualdub filter
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2011, 00:41 -
Problem using wipeout filter in virtualdub
By ahmed_mo2nis in forum Newbie / General discussionsReplies: 15Last Post: 8th Mar 2011, 22:53 -
Virtualdub and Filter Related problem
By frmys in forum EditingReplies: 26Last Post: 27th Jan 2011, 12:16 -
VirtualDub filter
By nic3 in forum EditingReplies: 6Last Post: 30th Sep 2010, 09:48 -
VirtualDub Filter for problem with "Horizontal Sync Issues"?
By lonerzzz in forum RestorationReplies: 6Last Post: 6th Apr 2009, 17:29
