  1. Can anyone point me to a guide oun syunuc uthe sound with the lips
    it seems my sound is slightly quicker than the movie cause at the end it loses sync
    PLEASE HELP VERY FRUSTRATING
  2. While fixing audio that is out of sync exactly the same amount all the way through the movie can be done with some effort, the sort of problem where it's in sync at the start but gradually goes out of sync is nearly impossible to fix, and much more trouble than it's worth to deal with.
    May 2002
    Tacoma
    I had that problem recently. I was capturing from VHS and TV and it was gradually going out of sync. I was capturing to DivX MPEG-4 V3. Doesn't do it with DVD capture but does it with VHS and TV. I found out that it is not impossible to fix. After I do the original capture, before I save to AVI and dub to MP3 audio, I click on Video and then Frame Rate. And check the box that says Make Audio and Video durations the same. You should notice that the Video frame rate in the first box is different, (usually lower). Works for me. Hope it works for you.
