I am currently capturing 720X480 Composite video from VHS NTSC using uncompressed avi and converting to VCD. I can fit a little over an hour on an 80Gig Hard drive.
Would a smaller res. be more practical?
I am not willing to use a codec.
I was just wondering if I captured at, 320X480 or 640X480, or any other resolution, would it be just as good for VCD quality?
Thanks, Chad
I do the same, meaning, capturing UNCOMPRESSED then converting to either VCD or DVD. But let's concentrate on VCD.
I found that when I capture at 704x480, it gives me the same results. When I capture at 352x480, it gives me results that I believe is about 99% quality compared to 704/720x480.
Try capturing at 352x480, this should save a lot of HDD space and at the same time capture more time on your 80gig. I also use an 80gig JUST for my capture file with NTFS system.
Good luck.
Does Streamtransport have a practical simultaneous download limit?
By yoda313 in forum Video Streaming DownloadingReplies: 5Last Post: 31st Jul 2010, 18:56 -
Different screen size with different browsers
By disturbed1 in forum FeedbackReplies: 5Last Post: 27th Nov 2009, 05:10 -
Practical ways to callibrate VHS sources
By SatStorm in forum RestorationReplies: 31Last Post: 6th Aug 2009, 10:32 -
Is There a Practical File Size Limit For Streaming FLV?
By phild in forum Newbie / General discussionsReplies: 1Last Post: 18th Aug 2008, 09:13 -
16:9 Screen Size Question
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 10th Sep 2007, 18:43
