i am going to order a new motherboard and cpu. i believe that i want an amd cpu.
which chipset(s) should i be looking to get? i know that via is awful. anything else anyone can tell me?
THIS IS HARDCORE
c'mon somebody....
someone who has no computer crashes please let me know what you are running so that i can invest my money in the right place please.
thanksTHIS IS HARDCORE -
My Abit KR7A (Via KT266A) crashes in Premiere once a while. It was much worse before removing from using the RAID and installing the VIA latency PCI fix. Hope this helps. Frankly speaking, crashes are common when it comes to video editing.
i think i heard somewhere that p4 is like amazing for encoding if thats what you plan to use it for
thanks.
i was actually thinking about getting the abit kg7a-raid board myself... perhaps i won't since you can't use the raid on it then.
Im a die hard Gigabyte fan get the GA-7dx rev.4 it comes with the amd 761 but it doesnt have an onboard graphics chip which is why I got it but Im not sure what your looking for
i think i found my dreamboard
abit nv7-133r
onboard
lan
audio w/ optical out
usb 2.0
raid
3ddr
5pci
NOTHING VIA except usb2.0
nvidia chipsets
mmmmm
thanks ya'llTHIS IS HARDCORE -
I've got the epox EP-8K3A+, it got via chipset, but I've had no problems with it. Check my comp spec to see what I use it with, fast board and a good overclocker too.
Craig
Looking for ideal converter
By xtof in forum Video ConversionReplies: 11Last Post: 4th Oct 2011, 17:34 -
Ideal format to convert to
By The Monarch in forum Blu-ray RippingReplies: 2Last Post: 23rd Jan 2011, 20:35 -
DVD to AVI ideal settings
By jbaruch76 in forum DVD RippingReplies: 11Last Post: 4th Nov 2008, 16:40 -
Ideal DVD Recorder for this job...
By retroborg in forum DVD & Blu-ray WritersReplies: 9Last Post: 17th Sep 2007, 15:29 -
New, ideal system - is it possible?
By TCIslandTime in forum DVD & Blu-ray RecordersReplies: 1Last Post: 31st Jul 2007, 20:45
