Hello,
The DVD 2 CVD software that I have requires me to use MPEG format, when there are VOB files, how to I make VOB files into MPEG?? please let me know with any help. thanks
Mike
hello friend ...
need some help ? pay money .... joke joke !
yes , u can man
go to a site that have also install program for flask !
http://www.geocities.com/installflaskmpeg0594
hope im helping u now ! :P -
i personally use DVD2AVI to make an audio file and m2v project. i then use TMPGenc to loa dthe project as the video source and the sound file as the audio source and re-encode it to a dvd compliant mpeg-2 file.
help with DVD2AVI can be found here...
http://www.vcdhelp.com/DVD2DVD-R%20bigger%20than%204500%20megs%20from%20multible%20VOBs/
...just follow the instructions through the dvd2avi part then go to the next link
help with the TMPGenc process can be found here...
http://www.vcdhelp.com/tmpgencdvd.htm -
Do you have to totaly re-encode the vob to make it into an mpeg, or can you just change the .vob to .mpg like you can with .dat on vcd's??
Converting VOB's to MPEG 2
By HitTheRoad in forum Video ConversionReplies: 9Last Post: 9th Aug 2011, 04:46 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Converting .VOB to MPEG-2
By PHNeedsHelp in forum Video ConversionReplies: 2Last Post: 21st Jul 2010, 12:22 -
VOB/Mpeg to AVI??
By Rjupiter in forum Newbie / General discussionsReplies: 10Last Post: 20th Jul 2008, 08:00 -
vob and mpeg to dvd
By Dekaspace in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2008, 18:36
