Everytime I try to burn a VCD-compatible MPEG, Adaptec says the MPEG is not ready for VCD. A big "X" appears. This is constantly happening even though I use various apps to convert AVIs to VCD-compatible MPEGs. Help! Thanks.
A few details might help........
What Adaptec are you using? EasyCD Creator? Toast?
What Version? Standard? Deluxe? 4.xx? 5?
VCD Easy is also worth a try if yr well stuck -
Or get nero or CDRWIN. Since Ez CD Creator was bought from 5 on, it went down hill.
Using Adaptec 5.1 Platinum with the upgrade to XP installed. When I first started using it, it worked but consistently doesn't now. I own a copy of Nero but afraid to install it because the last time I tried that, it threw my new Sony Vaio PC into a constant "start up" loop and I had to reformat. Maybe one of the apps mentioned here is worth trying? Thanks.
890619 - convert TS to VCD compatible files.
By hamidi2 in forum VCDEasy GeneralReplies: 2Last Post: 9th Sep 2010, 18:21 -
Adaptec AVC-3610 Dual TV Tuner - NEED HELP!
By kookie2000 in forum Capturing and VCRReplies: 13Last Post: 7th Mar 2010, 09:56 -
MPEGs recorded with Sony DCR-DVD108 not compatible with any video software?
By MarcosJP in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Oct 2009, 23:15 -
[SOLVED] Adaptec AHA-2944UW WinXP Driver
By sdsumike619 in forum ComputerReplies: 2Last Post: 20th Oct 2008, 04:05 -
Onboard Raid 5 vs. Adaptec PCIE
By mike909 in forum ComputerReplies: 18Last Post: 2nd Jun 2007, 03:05
