  1. I am trying to convert an AVI I downloaded into MPG format, but at several times in the movie there are periods of several corrupt frames. It will play in Windows Media Player with distortion effects when it goes over the corrupt frames, but when I try to convert it it always stops when it reaches one. Is there some program that I can use to remove the bad frames or will convert it regardless? Thanks for any help
  2. it's best to always run DivFix before you convert
    http://www.divx-digest.com/software/divfix.html
    that will (should) take care of it
    your pal,
    Stinky
