Dazzle DM7000 DVC2
I am looking to buy an encoder card to encode all my old VHS videos and put them on DVD+R. I was wondering if anybody had any suggestions? Are those new ATI All In Wonder Cards any good? (7500, 8500DV)? If I do record all my old VHS tapes on my computer, how many hours can I fit on one DVD? (Probably going to record in MPEG-1 Format because thats as good as VHS tapes get).
Thanks!!![]()
I have the ATI 64 ddr Vivo for 150 bucks which works very good for me. I have been using it with VirtualDup, Tmpgenc, Nero. I have pIII 600 and 384mb ram. I got very little dropped frames when capturing from old VHS tapes and the CPU usage is about 20-30%. I use TMpgenc to encode and burn with Nero. The last time I put 93 minutes on one VCD and the result is ok. I am sure you can do better with Dvd. Make sure you have a large hard disk. The 93 min capture (350x240) takes 13 Gigs.
Good Luck. -
Hey,
Thanks for replying. How is the quality like on your VCD? Is it pretty much exactly how it looks from the VHS? Or does the quality suffer a lot? I am still debating whether a capture card that is dedicated to capturing (only has one purpose) produces better capturing than an All-In-One Card (gaming card, multimedia, etc.). I am willing to spend about $250 or so.
Thanks. -
I have been using my card entirely for capturing only. That is the only reason I bought it. I think the only card that is used only for capturing is a firewire type of card which captures DV Cameras.
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
